648 Views, 3 Replies
Label on underside of sheet not working
i tried checked or unchecked the option of "Label on underside of sheet"in insulation material properties,then redraw but the part of this material on the insulation nesting sheet still the same,no flipped over.Tried camduct 2017 and camduct 2018,same result.
the flip can only works on the "pattern switches-developments-Insulation Label on Inside"ticked or unticked.
