801 Views, 13 Replies
Fabrication mep file
Hi all,
I received a 3D dwg file, containing some elements inside that were created on Fabrication MEP (MAPS_SOLIDs). I'm working with Autocad 2018 and when I go to the layout tab, and try to use the "base view from model space", this elements simply do not display on the viewport. Any solution?
Thanks in advance,
Antonio.
