AHepker_HOB
in reply to: ben
You could also freeze the 2D and 3D pipe layers leaving only the CL layer. This wouldn't show connectors unless you are using a connection object (no-hub band) as a separate entity and on a separate layer controlled by the service.
Check out our blog @ HouseOfBIM.com
