07-06-2017
08:22 AM
- Mute
- Permalink
- Report
07-06-2017
08:22 AM
I'm trying to set up a notch for TDC. the turn over is 2" but it needs 2 5/8" notch to go through the roll former. In the connector dialog the seam cut back doesn't change anything. I can change the turnover to 2 5/8 but the part will be 5/8 too long. same as with other connectors like 1" Tap you have to cut the lock seam back further to allow clearance to bend it or form it.
07-11-2017
10:17 AM
- Mute
- Permalink
- Report
07-11-2017
10:17 AM
Set the Turnover to exactly how much material you need for the TDC connection, then add the 5/8" to the Straight column.
