327 Views, 1 Reply
Point Layout export Problem
I have come across a problem when exporting points from Autodesk point layout.
I can export the .csv file but when I open the .dwg and .csv file on my Trimble pad the points and background are way off from each other.
I haven't had this problem before and cant figure out the problem.
 The coordinates are set to world on both and the XYZ on the dwg is set t 0,0,0
