matthewweake
399 Views, 2 Replies
CAMduct Marking Location
Is there a way to control the position of the marking on the sheet?
CAMduct does an OK job of making sure it is on the part being cut but I can't find a way to force the marking into a corner for example. I want to do this to make it easier to read on large parts.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
in reply to: matthewweake
You can drag it to where you want the tag.
matthewweake
Do you mean editing the nest and then moving the marking? I don't seem to be able to select the marking to move it manually.
Matthew Weake
+64 9 302 4028
