05-19-2017
02:46 AM
- Mute
- Permalink
- Report
05-19-2017
02:46 AM
Dear Sir,
First of all many thanks to make my question as part of your review. Secondly, Yes, it is actually saying 1:96 in the tool-tip. I have also verified the elevations with the AutoCAD ID command as per your instructions and found accurate result so the pipe is taking absolutely correct slope as provided (1:96).
The problem is pipe elevation in the tool-tip is showing the same for both the ends.
you said in your earlier reply that, "If you go to the other side and it doesn't change to C2, then it is still reporting the Connector 1 elevation"
and i think this is the actual problem.
Sir, it would be a great help if you kindly provide some tips to get it corrected.
Please find attached to know the exact problem
