matthewweake
in reply to: Washingtonn
As you are drawing the design line you can select the bend you want from the buttons and it will be used.
Alternatively you can delete all of the items, place the required fitting at the node and fill in 3D.
For each one you have overridden, there is an X at the node.
Hopes this helps. (I got stuck with this too!)
Regards
Matthew Weake
CADPRO Systems Ltd
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
