05-05-2017
09:32 AM
- Mute
- Permalink
- Report
05-05-2017
09:32 AM
Different Types of Bends on same Design Line
A typical vertical plumbing waste offset has a Quarter BEND at top and a Short Sweep BEND at the bottom - two different BENDS needed on the same Design Line. Because of Button mapping, the first Button which geometrically fits the situation will be used. The result is that ALL BENDS of the same Design Line will fill with the same type of BEND. A user can manually change a fitting after using 'Fill in 3D' but with any use of 'Erase 3D Item(s)' and subsequent 'Fill in 3D', the manual changes are lost and will need to be redone - making further use of this Design Line a manual affair.
Is there any way use the Design Line 'Fill in 3D' and 'Erase 3D Item(s)' features without losing manual BEND changes?
