374 Views, 0 Replies
2018 Fabrication Cadmep develop tool
I've just loaded in 2018 fabrication cadmep 'trial version'. I have a database that I have used on the previous 2016 version. I've successfully pathed to the database and everything looks good. Toolbars etc and the catalogue content are all working fine. The database works fine on the 2016 version
However, when I draw a straight duct length over say the size 250X250 in 2018 Fab it reverts the overall duct length set in the 'database/fittings/specifications' from the set 'coil width' of 1504mm down to 144mm (making a duct length in the model 100 or so mm's. When I check the pattern that is created in the 'develop' tool it has flipped the x & y around hence why the produced new duct length is shorter. The x would normally be set at the 1504 and the y would be to suit the overall area of the duct required
Ant ideas as to why the x & y could flip on develop tool?
Ps tried unloading and reloaded twice both database and the software
