The solution (from Andy Robins)...
When you load CADmep or a DWG that contains CADmep objects, the application is basically in “viewer” mode UNTIL you use any command, then it checks the license out. I suspect if you double click on an object in the model or take a new object off, you will experience the same delay, then it will be fine and so will the API (as its licensed now).
Andy
