03-21-2017
09:14 AM
- Mute
- Permalink
- Report
03-21-2017
09:14 AM
Pipe bending or cutting at small angles
Hello!
Could somebody maybe help me in this case?
Under ~10 degree in the shop sometimes we are bending the pipes with a bending machine or if it's smaller degree like 2-3, we are cutting the pipes end in a small degree and then weld together. When I draw a Design Line and fill in 3D, at a small angle it left a big gap and I need there to bend a pipe, or if its smaller degree, joint the two pipe together with the top points, not the centerline because if the node point is in the center, and we will cut a small piece of pipe from the end in angle, the pipe will be smaller.
Thank you in advance!
Andras
