1168 Views, 3 Replies
CREATING NEW CONNECTORS ans seams in Camduct
hi
I just downloaded the trial version of camduct to test but don't know how to create new connectors and seams. is there a tutorial or video that use to learn this process?
Best Regards
Allen
Tags (1)
Hi Allen,
First thing I would recommend is going through the manual training for Camduct:
http://automated-products.com/download/CAM-Duct%20Training%20Manual%20-%202%20Day.pdf
There is a bit explanation about Connectors and Seams (default one) to give you an idea about them and where you can see and edit them. Secondly, you would want to back up whatever database you have before playing around with new connectors and seams. Following, you can go to database and look for Fitting Tab then you will see Seams and connectors.
From there you can play with them by changing different values in each Seam/Connector properties. Actually, there is one important thing that you might need to concern is about the Notches. Make sure you create appropriate notch for each new seam/connector so that you can actually form them in workshop.
Cheers,
Respected sir,
we faced many difficulty about creating new connectors, notches and seams in cam-duct soft were, so please help me and i hope u will provide satisfies reply and we loss our business because of some trivial problem and we have to do hard work, although we have cam-duct software so kindly request please send me video clip about connectors, notches and seams.
        Nikunj patel (9429180312)
dyoung
@Anonymous wrote:
Respected sir,
You may have better luck asking specific questions and posting the exact problems you are having. Your request is so generic in nature, you're essentially asking someone to explain the entire software package in a forum post.
Review the CAMduct Fundamental here...
https://www.youtube.com/playlist?list=PLY-ggSrSwbZpoJpqAK1R9m9pt4sFb0wjw
You can also purchase a CAMduct Fundamentals book here...
http://www.asti.com/Fabrication/Courseware/
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
