571 Views, 3 Replies
02-24-2017
08:51 AM
- Mute
- Permalink
- Report
02-24-2017
08:51 AM
The first time that the Job.Info object is accessed it takes 20 seconds to continue to the next line.
oDR.InfoCreationDate = Job.Info.CreationDate;
// Command.cs...
namespace McKenneys
public class DuctDataExport : IExtensionApplication
public void Initialize()
//string sFile = @"Autodesk\Fabrication 2017\CADmep\FabricationAPI.dll";
//string sPF = Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.ProgramFiles), sFile);
//Assembly MyDALL = Assembly.LoadFrom(sPF);
//Type MyLoadClass = MyDALL.GetType("Autodesk.Fabrication.Job"); // name of your class
//Activator.CreateInstance(MyLoadClass);
[CommandMethod("FabAPIDuctDataExport", "FabAPIDuctDataExport", CommandFlags.Modal)]
public void Execute()
try
ClassStatic.SetApplicationProperties();
ClassStatic.PopulateDataTables();
new ClassFabrication();
catch (Exception ex)
MessageBox.Show(ex.Message);
public void Terminate()
// ClassFabrication.cs...
namespace McKenneys.Classes
public class ClassFabrication
// Constructor...
public ClassFabrication()
Data1UpdateProject();
private void Data1UpdateProject()
// Create new strongly-typed DataRow object.
var oDR = ClassStatic.ProjectJobInformationDT.NewProjectJobInformationRow();
oDR.ProjectId = _ProjectId;
oDR.InfoDescription = Job.Info.Description;
As you can see I've tried Assembly.Load from two different methods.
What do I need to do to resolve this?
Randy
