andy.robins
in reply to: Earl.Harris
The reason you are getting 2 lines is because you have the connector name in the export so you get one line for each.
To rectify you can either select "Merge Rows Together" on the Order tab but that will only work if the connectors are the same at both ends, OR you can set "Display Data for Index" and specify 1 in the Contents tab so it only shows the connector at end 1.Export.PNG
Andy Robins
Engineering Manager
