Wow, pretty harsh. I received the lisp from a sheet metal detailer a long time ago and it didn't work right so I had to tweak it a little. Took forever since he, nor I, knew basically nothing about writing lisp routines. Also, I wanted to distribute to all the Detailers within my company, once I got it to work right. Management wouldn't allow it with an Author name within the lisp text, by someone not working for the company. So, it was either place my name on it or the company's name. I chose mine because if I placed the company's name on it, I was told I could be hassled later for distributing it outside the company, especially if I didn't work there anymore. That said, I did state that I was very green in Lisp Routine writing when I posted this issue on Autodesk Forum. I thought it was pretty obvious that I received help. I can understand your issue with it but I just wanted you to know the reason. I will try your suggestion and see if it works. Thanks.
Sincerely,
Eric Botts | BIM Detailer
Pan-Pacific Mechanical
1205 Chrysler Drive, Menlo Park, CA 94025
P: (650) 561-8810 | F: (650) 561-8811 | C: (916) 796-8103
ericb@ppmechanical.com | Pan-Pacific Website| Please Contact Us
[cid:image003.jpg@01D286DB.EFC26520]
________________________________
This e-mail, including any attachments, is the property of Pan-Pacific Mechanical and is meant only for the intended recipient and may be a confidential communication. If you are not one of the named recipients or otherwise have reason to believe that you received this e-mail in error, any review, use, retention, dissemination, distribution, printing or copying of this e-mail is strictly prohibited. Please notify the sender immediately of the error by return e-mail and please delete this message from your system. Thank you in advance for your cooperation.
