davidronson
Not that I'm aware of, it sees the branches as a change of direction so it is throwing in the Before/After. I would like to see this posted in the Ideas Station, if you post it there I will give it Kudos.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
