Hi
Check you're license file.  You should see a line that says BORROW='number' Autodesk usually issue the file with 4320, the number refers to the number of hours you can borrow it for.  The other thing to check if this is correct is that you don't have an options file setup on FlexLM that could also be limiting your borrow period.
Regards
Simon
