Earl.Harris
345 Views, 1 Reply
CSVEXPORT Duplicating Lines
When using CSVEXPORT to create an Excel file the pipe items are being duplicated.
Item NoQtyNameDescriptionSpecificationConnector
3127.659 (inch)Pipe-A53-CS-(B)-SCH80-BLK(PE)20'' GRC_Tube_Plain End
I am filtering out all the other parts( by CID) to leave just the pipe. I only need the one line so the quantity fields will total up correctly.
andy.robins
in reply to: Earl.Harris
The reason you are getting 2 lines is because you have the connector name in the export so you get one line for each.
To rectify you can either select "Merge Rows Together" on the Order tab but that will only work if the connectors are the same at both ends, OR you can set "Display Data for Index" and specify 1 in the Contents tab so it only shows the connector at end 1.Export.PNG
Andy Robins
Engineering Manager
