davidronson
in reply to: johnwbrown573
That means it is a Managed fitting and thus has been locked by either Autodesk or Building Data. You will not be able to edit the Product List. You will need to rebuild the fitting. Autodesk has since unlocked all of their Product Lists, but I am not sure if you have BD or Autodesk content. You can find out, in Folders right click on the fitting and go to Owner Information.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
