477 Views, 1 Reply
Carbon Steel Pipe wrong OD
In Fabrication CADMEP 2016, Apparently, there is a size chart for IPS Piping called Nominal.   This chart must fix the sizing for IPS piping, but is not working for downloaded carbon steel piping.  The fittings are displaying correct however.  The properties information tab shows the diameter type as outside.  Needs to be fixed to nominal but edit option is locked
simon_dickinson
Hi Mark,
Are you using one of the standard configurations?  If you copy it you should be able to remove the padlock and edit.
regards
