davidronson
Fabrication handles this using Cut Type, when a straight is full length the Cut Type will be Decoiled Straight, when a straight is NOT full length the Cut Type will be Machine Cut. I don't think there is a way to do what you are trying to do.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
