350 Views, 1 Reply
Service Template Help
Can someone please assist with the following:
We are trying to set up our database so that when we do design to fabrication in Revit, standard length ducts and cut ducts are not the same fabrication part.  We have tried adding multiple buttons to our service template and locking their set lengths, this however has not worked.  All of our ductwork is being converted to the standard coil duct in the fabrication in Revit.  Is there button mapping required to accomplish this?  Please help.
davidronson
Fabrication handles this using Cut Type, when a straight is full length the Cut Type will be Decoiled Straight, when a straight is NOT full length the Cut Type will be Machine Cut. I don't think there is a way to do what you are trying to do.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
