345 Views, 2 Replies
Lost login credentials
How do I reset the login credentials for CAMduct 2017? The person that setup all of the login credentials is no long with the company.
Thank you,
davidronson
Go to Start>Autodesk>Fabrication 20XX>Configure Users, you can make the changes there.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
That worked. Thank you!!
[Hoyt][2) Email] [FB]
Confidentiality Notice: This message and any attachments may contain confidential, proprietary or privileged information originating from Cunningham, Inc. that is protected by the Electronic Communications Privacy Act, 18 U.S.C. §§ 2510-2521. It is transmitted for the use of the intended recipient(s). If you are not the intended recipient or their designated agent, you are hereby notified that any use, dissemination, copying or retention of this email or the information contained herein is strictly prohibited. If you received this email in error, please contact the sender immediately and permanently delete this and all copies of this message
