Washingtonn
Here is the link to an updated video solution for the original situation.  I still like the Trace option best - I think it is easier and allows the pipe routing to be generated without first having to set the size.
One of the short sweep fittings was replaced using the single fitting swap,  the whole process was completed in under 2 minutes.
https://youtu.be/jTH3lf6dnBc
