davidronson
in reply to: mholper84
Applied Software has a renumbering tool specifically for Fabrication parts in Revit. It takes also takes advantage of the exposed Item Number field so the information will export with the .maj.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
