- Mute
- Permalink
- Report
Hi!
My problem is, that we are using welded connections for a pipe and fitting joints and for a pipe-pipe joints we are using couplings. And after, when the 3D modell finished, we are cutting the system for spools with coupling joints.
I can't place a grooved connectivity coupling in a welded pipe systems. I changed the coupling connectivity properties to welded,it joined, but in this case I can't see which end is grooved and which one need to be welded.
Can I add multiple connectivity properties? Or is it possible somehow, that when I place a cutting coupling in the pipe system, automaticaly change the pipe properties?
Does somebody know some solution?
Thank you very much in advance,
Andras
