About the NC code you might need to go to the Set up of Machine to check the Post Processor to find the right VLP file that you need to use to get the compatible code for your machine. About the nest I don't think it's related to the machine setting so you might need to decrease the margin just to enough for compensate your tool width which is about 2mm for normal plasma
