Hi @Donovan.james,
Im assuming its a laptop if you have an M2000? If you use the command "3DCONFIG" it should tell you if its using the Quadro for graphics or an intel chip. It is common for laptops to have two graphics chips, your computer might try to be smart about choosing which chip to use and might be using the intel chip to run Cadmep.
See this Autodesk article to see if this is your issue, if it is you should be able to turn this off in the bios:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
let us know if it fixes your issues.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
