- Mute
- Permalink
- Report
Copy Design Line
Dear forum, I have an issue.
When using the cpydlsel command, the software uses the origin of the model as base point for the copy, not the origin of the line.
I have tried all I could think off and nothing works.
Have anyone had the same problem? How can I fix it.
Thanks!
- Mute
- Permalink
- Report
There was recently work done on the Copy Designline feature and if you haven't service packed yet, then give it a shot. If you have maybe roll back? Check those command prompts, it mentions toggle and that is just a T->Enter to do a toggle.
- Mute
- Permalink
- Report
I have the service pack installed, but Toggle does not give you any chances of changing the origin point.
- Mute
- Permalink
- Report
I finally got around to rolling out the SP1 update and I think I see your problem. The CPYDLSEL command is definitively acting differently, but not fundamentally. From what I can tell they simply broke the AutoCAD Jig (temporary objects for visual representation) they used to dynamically produce while doing the copy.
I don't think it is actually using 0,0,0 as a basepoint, but you can't see the dynamic representation of the copy you previously did. As far as I can tell the copy basepoint is still based on the order of your selection and the flow of the design line as always.
This is a bug and they need to fix it, contact customer support.
