- Mute
- Permalink
- Report
Making the ductwork lines wider.
- Mute
- Permalink
- Report
This sounds like something you can fix with AutoCAD rather than cadMEP settings. Maybe you could post a picture of what is wrong?
LWDisplay set to ON and changing your layer lineweights (in the cadMEP services) to be thicker might be what your looking for, but without a better idea of what your seeing it is hard to say.
After you've tweaked those settings, be sure to do a RebuildAll to regenerate the layers on the existing objects.
- Mute
- Permalink
- Report
The last time I was working on the duct line thickness was about a year ago. And I didn't realize lwdisplay was off. So It is shows when I change the line scale through autocad. Thanks for the reminder. I was hoping to set it up in Fab cadmep so I wouldn't have to set it up every job. I tried to set it up in takeoff/services/cad types. But the max width it can be set to is .083 inches.
- Mute
- Permalink
- Report
I've never had a need for something more extreme than 0.083, but if your project does then just edit your AutoCAD layers. Once fabrication dynamically creates a layer, it pretty much never touches them again.
