763 Views, 4 Replies
Fix and Rotate dialog missing....
Hi
Can anyone tell my why when inserting drainage bends to a falling run, I no longer get presented with the fix and rotate dialog?  Is there some variable that I'm unaware of?
Many thanks
An angle tolerance must be specified on all fittings you want the fixer dialog to automatically popup while entering.
MOatman
There is also a checkbox to override thay setting in the services editor.
Cheers Moatman :slightly_smiling_face:  That was it!  Dunno how it'd been turned on, but unchecking that box has worked :slightly_smiling_face:
Many thanks!
If the angle tolarence option is missing in the "Edit" pop-up, how to add that option to specify a value? Please refer snap.How to add Angle Tolerance.jpg
