We currently do put the DWG's in the same location as the ITM and that does work, but what I am wanting to do is put them in the root of my VALVE's folder and have ITM's point backwards. I need this because we have tons of duplicated valve geometry between different wall thicknesses, slightly different stainless grades, dissimilar connectors that I just let the pattern draw on a plain end block, etcetera. It just causes a lot more dwg's to reside in the database than should be required.
A predefined centralized location of any kind (thinking map.ini) would even work fine. Maybe this is another idea station thing?
