markcalloway
Hi @Anonymous
I can see no one has got back to you so I will have a go at seeing if I can help.
I have found the following guide which might have some settings which will help:
https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Fabrication-UsersGuide/files/GUID-589F9911-9C9B-404F-BCB9-2B16405D545C-htm.html
Please have a read through and see if you spot any settings that sound like it will do what your wanting.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
