markcalloway
Hi @Anonymous
I can see no one has got back to you so I will have a go at helping you although this isn't my primary software.
I found some instructions that should allow you to customise your BOM:
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Plant3D-UserGuide/files/iso-style-tb-bom-configure-to-htm.html
Hopefully this will be of some use to you.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
