235 Views, 0 Replies
CAM Duct spot welding settings
Hello, Can someone help. How do I set CamDuct to mark sign to show (Spot weld 20) when cutting spiral pipe. I always use spot weld 20 as a joining seam but i had to manually mark the length as there is no dot sign show where the joint start.
