- Mute
- Permalink
- Report
Just like the title said,I have found the settings of default rectangular connector,but I couldn't define it to any existing connectors.The combobox always has nothing to select.Plese tell me how to solve this issue.
- Mute
- Permalink
- Report
I have used specifications (under fitings in the database) to define my connectors. You could make a real simple spec to just choose the default connector, but there are many other things to add as well. SUch as standard straight length and standard seams.
I myself use multiple specifcations to suit the job I am currently doing and it is controled also by duct size breakpoints. I find that half of the pattern options just don't work anyway.
Good luck, and let us know how you went.
- Mute
- Permalink
- Report
Hi UnitedDrafting,I use the same way just as yours to define the connectors currently,Thank you for your advise!
