721 Views, 5 Replies
Post processor
Is CAMduct has post processor to the following cutters:
Plasma Eurocut 3001.15p
Laser FiberCut II ( CutTech LC2512) ?
thanks for replies
That particular machine doesn't sounds familiar but that doesn't mean there isn't a post for another machine/controller that will work.
Note, in 2016, you can now create a custom post allowing you to setup a machine without a specific post processor.
jarios
Hi darren
Do you have any literature about creating postprocessors in camduct 2016?
LanceTSM
in reply to: jarios
If you know the controller used on each machine you can check if it is currently supported via this link.
https://knowledge.autodesk.com/support/fabrication-products/getting-started/caas/CloudHelp/cloudhelp...
in reply to: LanceTSM
Is there some post builder or some other way how to create your own custom post? Or how to customize one of the preset posts?
I mean to create or edit the VPLs?
thx
LanceTSM
Yes, from Version 2016 onwards there is the facility to add a "Custom NC Machine" and specify the required codes to match your machine.
See link to Help file article below:
http://help.autodesk.com/view/FABRICATION/2018/ENU/?guid=GUID-9C0A1ACA-41AE-41BB-8746-6C0AACE17AC9
