09-22-2015
12:44 PM
- Mute
- Permalink
- Report
09-22-2015
12:44 PM
CID 761
This fitting is not allowing me to input anything in the Top Outer Connection other than an equal number of the throat. ![]()
10-01-2015
03:11 AM
- Mute
- Permalink
- Report
10-01-2015
03:11 AM
Hi tdelara
You have a Straight Adjust on the connector you are using, that is causing it to fail. The Straight Adjust was only designed to be used when jobs came in from CADduct or CADmep without an extension on a Throat, over the years people just started using it to make connectors when it is not needed.
If you have .5 turnover and .5straight it is just going to add 1" on the end, so just make it a 1" Turnover and get rid of the Straight Adjust.
Dave Dykes
