davedykes
in reply to: eknight
Hi eknight
Have you set up an installed machine for Linear Nesting?  The Linear Nesting is not a physical Nest like when creating NC for a cutter, it is used to optimise cut-to-length materials that are typically bought and available in standard lengths, and then cut to fit into other ductwork components, such as elbows and tees, etc. Other materials that might be cut to length in the same way include flange material, tie rods, stiffeners etc.
Dave Dykes
