eknight
753 Views, 7 Replies
CAM 2016 not able to linear nest
In the 2016 version pressing the Linear Nest button does nothing and brings up no dialog.  Has anybody else seen this problem or know of a fix for it?
davedykes
in reply to: eknight
Hi eknight
Have you set up an installed machine for Linear Nesting?  The Linear Nesting is not a physical Nest like when creating NC for a cutter, it is used to optimise cut-to-length materials that are typically bought and available in standard lengths, and then cut to fit into other ductwork components, such as elbows and tees, etc. Other materials that might be cut to length in the same way include flange material, tie rods, stiffeners etc.
Dave Dykes
eknight
in reply to: davedykes
I have it setup and we depend on it in 2015 cam. It works in 2015 just fine but in 2016 when I select the linear nest menu item it does not even open a dialog box that shows items to linear nest.
Eric Knight
Arctic Sheet Metal
phone: (503) 280-5814
e-mail: eknight@arcticsheetmetal.com
davedykes
Hi Eric
Did you carry out a Migration of the settings in 2015 (Using the Autodesk Migration Tool), or have you just linked to your existing 2015 Content?
Dave Dykes
eknight
I just linked it to the 2015 content.
Eric Knight
Arctic Sheet Metal
davedykes
Hi Eric
I have just ran a test in 2016 and you are correct, the Linear Nest under the Utilities Menu doesn't do anything.
It does however work if used in a Process.
I shall log this with the Development Team.
Regards
Dave Dykes
eknight
Well at least it runs under process. Which is where we use it day to day. Thanks for looking into it.
Eric Knight
Arctic Sheet Metal
jazpearson
This has now been fixed and should be available in the next service pack update.
