in reply to:
11:00 PM
- Mute
- Permalink
- Report
07-27-2015
11:00 PM
Hallo Autodesk,
We have set rotation angles to 10 and 90 degree. It still do not rotate the part.
The sheet size is 1500 x 3000 so the part is 1550 x 900 which is not an oversize part but CAMDUCT identify it as a oversize part and want to nest across sheet (1500 side) and not rotate it so that it is nested on the 3000 side.
In manual nesting when trying to rotate the part it will not rotate the part 90 degrees to make it fit.
Is there a way we can export our data base to you so that you can investigate this error?
Wold you like to connect by remote desk top?
Regards
[Description: cid:image001.jpg@01CD1185.6BDCFDE0]
Jaco Swart [Description: ADA-Logo-2012]
4b Diagonal rd , Eastleigh , Edenvale
T +2711 372 6380/1
F +2711 450 4317
C +2771 107 8063
E jacos@advantageair.co.za
www.advantageair.co.za
Regards
T +2711 372 6380/1
F +2711 450 4317
C +2771 107 8063
