josh_spencer
255 Views, 0 Replies
Need help nesting full joints of duct vertically
Hopefully someone on here can help me as i've been spinning my wheels with TSI support. We work with 120 x 60 sheets of metal and sometimes cut full joints of duct out on our cut table. The problem is when i go to nest a 59" joint of duct(stetchout would be 60") the program wants to nest them horizontally or diagonally. Also if the joints dimensions equal more than 60" it wants to 2-piece the fittings. This waste a TON of metal. I've set my settings to edge nest and nest parts equal to sheet with. I've turn lead in options to 0.00 and when i go out to our cut table, it wont start the job and tells me the path goes out of bounds. Can someone please give me a detailed step by step of where to go so i can start nesting full joints of duct vertically on our table.
Thank you
