04-20-2016
06:19 AM
- Mute
- Permalink
- Report
04-20-2016
06:19 AM
We are using a database and items from previous releases of Cadmep. Using those it will not fill clevis hangers on 2017 in designline. You are right that if we use the new imperial dtatbase that comes with 2017 it does fill the clevis hanger. Something is amiss in the 2017 version that won't fill older versions of the same item. It would be too costly to go and recode and replace all the the different pipe hangers we use just to make thie 2017 version work. It should work with previous version items as well. I am not the only one that has found this. Check the Xtracad site, it is starting to pop up with others as well.
