KennethSchwind9483
527 Views, 3 Replies
Criteria in design line not applying to spiral couplings
When drawing with designline and the criteria applied, all items except couplings contain drawing number, section, etc.
This was not a problem in EST 2015 but for some reason it is now in EST 2016. Maybe the update changed something because we have drawn spiral before that on 2016 and no issue with the criteria not showing. Any Ideas out there?
Hi KennethSchwind9483,
I've logged a case with the team so they are aware of the problem in Fabrication 2016 and can consider when planning for future releases. I'd hoped to offer a workaround but don’t see we have access to the DL Criteria fields for Item Scripting, will update you if a method is found in the meantime.
Thanks you for the feedback!
Nicholas Hyland
It also appears the copper joints, copper couplings, and sheetmetal couplings do not carry some criteria (ie. sections) information when using designline in EST. Everything else carries the criteria. Would be nice to get this little bug fixed.
in reply to: Nicholas.Hyland
We need to have this bug fixed!
