302 Views, 0 Replies
07-31-2015
04:22 AM
- Mute
- Permalink
- Report
07-31-2015
04:22 AM
Spacing specification calculating incorrectly ESTmep 2015
I am currently setting up a specification in Fabrication ESTmep 2015. I am having trouble with the spacing criteria as it is not calculating the correct amount of supports needed on the straight item.
Currently, I have set up the specification for standard straight lengths of 1500mm for all dimensions. The spacing required for the supports is 3000mm.
When I did a test for 6 straights of 400x400 (9000mm) the program seems to add a spacing for every straight (I.e. 6 supports). The correct amount of supports needed here is 4.
How can I amend the database to ensure the spacing is working by the length of overall duct and not by per item?
Kishan
