1246 Views, 9 Replies
Aqua Therm Content Request
I am having alot of jobs that are requiring this and would like to use Autodesk content.  Can you put this on a list of content requests? Thanks Josh
Have you contacted Aquatherm? If they don't already have .itm files they might create them for you.
You can always create your own. Aquatherm would be pretty straight forward to create.
cadbob2
You posted in Sysque Forum looking for the Content, but now you are in a Autodesk Forum looking for the same content. You will not find Sysque Content here, contact them for a fee they will make it for you.
in reply to: cadbob2
cabbob2, if you're a SysQue customer we don't charge for content.  If you provide us with the PDF Cutsheet/Specification, we will build that content for free. I did check the site and we have 245 Revit Families per the product lines below.
cadbob
There you go jossin!
I don't believe you can do today's job with yesterday's methods and be in business tomorrow.
PDavison7901
Jossin,
Did you have any luck sourcing the Aquatherm content?
Paul
cadbob
in reply to: PDavison7901
You can check Building3dcontent.com and also request Aqutherm. They are not difficult to Build if you decide to build yourself.
The other poster Keastman17 seems to have lost his way not knowing this is a Fabrication Forum as opposed to some other software he suggested to buy to get a Library. (Most be a Salesman)  Aquatherm does have a Free Revit Library of there fittings you can use in Revit or Convert to Fabrication without the added costs as he suggested.
Spoiler
in reply to: cadbob
I have the system in Building Data. I am in the process of building it.  Thanks. I have requested several several months ago on building3dcontent site.  Have not seen it yet. I am sure it will come. Thanks for all your resposes. Josh
cadbob
Once you finish Building your 1st Library with Content, you will have more confidence and be self gratified.
That is awesome news a good luck! :slightly_smiling_face:
in reply to: cadbob
CADBOB, I'm not lost you're the one who mentioned SysQue and were incorrect in your comment (hence my post).
I'm providing the user a solution that works today.  Building Data has over 5 millions lines of Metric/Imperial content.  It's the largest MEP database in the world.  A link to www.building-data.net is even included in the installer of Fabrication products as a content solution.
Also, I wrote a great article for AUGIWORLD talking about the difference between building or buying content (AUGIWORLD).
Some people build content and some people buy.
