nathan.chapman
If you are having issue with object enablers then remember the file type will be .DBX not ARX.  Also be aware that you will not install using the .ARX/DBX.  Once downloaded Autodesk will extract into your root C > Autodesk.  Go to that folder and should notice a Setup.exe.  Run that.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
