09-07-2016
02:32 AM
- Mute
- Permalink
- Report
09-07-2016
02:32 AM
Fabrication CADmep file not opening
I have Fabrication CADmep file which is opening (2014 Version) after more than 6 to 7 (six to seven) hours. I have prepared after opening the file
1) Audit the file
2) Applying DWG purge
3) Normal Purge
4) EXPORTTOAUTOCAD command applied
5) Saveas with the different name
Still the issue does not resolved. Have any idea to resolved issue ??![]()
Please, suggest
08:07 AM
- Mute
- Permalink
- Report
09-20-2016
08:07 AM
I can see no one has got back to you.
You could open a blank drawing and try using the RECOVER command to open the problem file.
Also try DXFOUT and save your drawing as a DXF then open it and save back as a DWG and see if this helps.
Let us know if you are still having issue and i will see what else you could try.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
