- Mute
- Permalink
- Report
Fabrication CADMEP 2016 HELP
I need to add a unistrut that is slotted, ive searched the internet for a file to download and import in to cadmep but i cant get to work or i cant find the right file. How do i go about
- Mute
- Permalink
- Report
The item has to show the slots? What are you trying to do with it. I attached a txt file that has a basic 2" wg service with unistrut hangers. Now they do not show the slots. download the file and change the extension from txt to iez. Import this into your database. You will have to clean out things you dont want.
Nate
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
- Mute
- Permalink
- Report
You can add holes and slots to unistrut CID 910 by modifying the dimension "Hole Width, Hole Depth, and Hole Spacing".
I have attached an ITM and PNG file for your use. Modify to suit your needs.
Change the file extension of the attached TXT file to ITM.
- Mute
- Permalink
- Report
